6.0 White smoke, Maybe EGR cooler? Input please before ordering new cooler. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-06-2010, 06:53 AM Thread Starter
My Father in-law has a 2004 Harley F-350. Rig has 78k on it, and is treated very nice. He idles it 15 min before driving it every time, but shuts her down immediately when he gets to his destination. That's all i can think of as far as info needed.
Now here is the problem. The truck spits white smoke. Not alot. Starts fine, idles fine, has 100% power. But after 10 min when she starts to warm up, the white smoke starts. Does not do it under WOT, or when stopped, only when coasting down from speed, and under steady throttle. the tailpipe is full of wet soot.
So after searching here i found that the EGR coolers on these vehicles seem to be troublesome. So in order to ensure that $400 on a new unit from bulletproofdiesel.com is well spent, we pulled the EGR to verify whether or not it was wet. The tip of the plunger seemed to be a little muddy, but the unit as a whole was not soaked. Same with the hole in which it came out of. It was pretty dry as far as i can tell. But i did notice some coolant in the valley, but could not see where it was coming from w/o pulling the turbo off.
My questions to you all (sorry of uber long post):
1. Does this sound like an EGR cooler?
2. What does it only exhibit this some under certain load conditions? I assumed it would be at all times.
3. Is there anything else we can check easily enough to determine the problem w/o putting her out of service for a few days? (Daily driver + plow truck)
If any more information is needed, please let me know and i can get it to you. Thanks!
Jorako is offline
post #2 of 4 Old 03-06-2010, 07:24 AM
blue06crew's Avatar
Sounds like gummed up EGR..possible EGR cooler cracked...the wet soot in tail is called "coking"...basically thing to do is pull out egr and clean is up and keep in unplugged..best thing would be to get a EGR eliminator kit and delete the stupid thing...they cause more harm and "no" good!
2006 Ford F-250 4x4 Crew Cab
SCT- DJ's Looney
AIRDOG 2
6" Rough Country 4 Link Suspension
2" billet spacer/f350 rear block
AFE air intake
5" MBRP turbo back exhaust with 6" tip
Autometer Sport Comp Guages
38.5x14.5x17 Pro Comp Xtreme ALL Terrains
17x10 Diamo Black 17 Karat Wheels
RCD EGR delete
Custom Traction Bars
Recon Smoked Mirror Lights/Cab Lights
03 Turbo
to be installed:
Whatever i buy next...
blue06crew is offline
post #3 of 4 Old 03-06-2010, 07:33 AM Thread Starter
Thanks for the Reply. Is this "coking" normal? The EGR solenoid wasn't too bad. It was replaced about 14 months ago after it had seized open and was throwing a code.
Jorako is offline
post #4 of 4 Old 03-06-2010, 11:38 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
probably and EGR cooler failure..best bet is to delete it and never have to worry about it again.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
