Major Problem with a ton of questions. - Ford Powerstroke Diesel Forum
Old 03-03-2010, 02:52 PM
2004 250 cc sb 4x4 6.0
dad used truck to go run around. Said it started to Over heat. Added water and it was fine then start dwn road again and just before he got home it over heated again. Now we try and start and it clicked like dead battery. Charged for a few and now it acts like the motor it froz but it turns over every now and then but not all the time. So the questions are....
1: did he just fry my motor?
2: could I just replace something to fix?
3: what is the cost of a new motor, installed?
4: is it hard to do myself to change the motor?
5: if it is something else can I do it mayself?
Old 03-03-2010, 02:57 PM
duct tape & zip ties
Pull the glowplugs and try and turn the truck over. I say this because it could be hydralocked. If it is then it will not turn over and if you keep trying you could bend or break a rod or push rod.
I would do this, if it is hydra locked you need to figure out why it locked. Then you can go from there.
Old 03-03-2010, 03:25 PM
Since I posted this I put the truck on a slow charge. Turned over and crank up like it always does. The thing now is that it poured water out the tail pipe. Is this a head gasket or even a egr cooler that could be doing this? Thanks for the fast reply BC!
Old 03-03-2010, 03:27 PM
Powerstroke Techie
Another classic EGR cooler failure by the looks of things.
Old 03-03-2010, 03:32 PM
I am with M-chan68 on this as well. Now that you have it running.
Old 03-03-2010, 03:41 PM
Thanks guys. What is the cost to buy one and do either of you know how to tell me to replace it. You guys are great. I am becoming a full memeber next week after I get paid. Oh, can I dive it with the cooler bad or should I let it sit til I replace?
Old 03-03-2010, 03:44 PM
i wouldnt drive it like that. let it sit. also, if possible, you should delete that egr. that way this wont happen to you again!
Old 03-03-2010, 04:09 PM
Don't drive it and if it was me. I would look at the egr delete mod for your truck.
Old 03-03-2010, 04:10 PM
So I should just buy a egr delete and that will fix? How much where can I buy in the Dallas tx area and can you tell me how to install?
Old 03-03-2010, 05:50 PM
Turning diesel into noise
I really like this kit from Sinister Mfr and its easy to install depending on your wrench turning abilities.
6.0 Ford Powerstroke EGR Delete Kit
I think the Techs will back me up on this one, DON'T DRIVE IT or you could very likely be replacing the head gaskets and possibly the heads if they get warped.
