can a bad injector do this? - Ford Powerstroke Diesel Forum
Old 03-03-2010, 05:41 AM
Can one or more bad injectors dump so much fuel into the cylinder to water down the engine oil and after sitting overnight fill the combustion chamber with enough fuel to hydrualic the motor? My oil level is about an inch an a quarter too full now, smells of diesel, and the engine cranked a few times and locked up.If this is the case, taking glow plugs out,cranking motor over should blow fuel out and show me which injector is bad, correct? And does the starter have enough torque to bend rods, pop heads? I know I'm screwed, just trying to figure out how much.
Old 03-03-2010, 06:46 AM
Feedback Score: -1 reviews
ive had injector tips crack and dump rraw diesel into the cylinder, hyrdolocking the engine and smoking like a freight train.
Old 03-03-2010, 10:57 AM
To answer the second part of your question, yes you can bend rods,valves,push rods etc. Take out your glow plugs and slowly just bump over the motor to push the fuel out.
It will relieve the pressure and show you which one is damaged. Do this in little spurts give it time to clear the fuel out, that glow plug hole is kinda small.
Old 03-03-2010, 12:39 PM
also check your coolant level and make sure its not low or empty, an blown egr cooler can cause a hydrolocked engine as well.
Old 03-03-2010, 05:11 PM
Illiana Chapter Director
A leaking ICP can allow fuel to get in the crankcase also.
Old 03-03-2010, 09:00 PM
no EGR valve or cooler to worry about, i did the River City delete a while back. Weird thing, while it didnt run very good last time it ran, it didnt smoke.maybe this weekend I can go skin a few knuckles on it.
