Help...Cracked Oil Pan - Ford Powerstroke Diesel Forum
Old 03-01-2010, 06:16 PM
Exclamation Help...Cracked Oil Pan
Anyone know what I might seal a 1 inch hairline crack on the bottom of my oil pan with? Not sure which jb weld product or steel putty may work best. Thanks.
Old 03-01-2010, 06:19 PM
how did you get a crack in it an if i was you i would replace it welding that is kinda risky
Old 03-01-2010, 06:25 PM
Powerstroke Techie
For the relative ease of access to the oil pan, I tend to agree that replacement is the best repair.
I would deff replace the pan, supposedly it is not terrible to drop the pan on these 6.0's
Old 03-01-2010, 06:27 PM
I just need a temporary fix. Could I weld it while its on the truck? The oil is drained. Oil pan got in a fight with a rock and lost.
Old 03-01-2010, 06:32 PM
Powerstroke Techie
If the pan is cracked enough to cause a leak issue, you will be hard pressed to "Band-Aid" it successfully with a weld. For what it's worth, any successful welding (be that with JB Weld, MIG welding, Oxy-Acetylene etc.) will require a clean DRY surface to work with. In other words, with the pan on the truck and oil leaking through it during the process, the likelihood of success is slim to none.
Old 03-02-2010, 04:49 PM
Powerstroke Techie
I mig welded an oil pan on a racecar with gasoline-loaded oil still in the pan.
It went rounds, but you had to have the heat WAY up to dry the surface as you weld it. Dangerous as hell, but if you think about it, if there's no air in the pan, no chance for combustion. Right? Right?
Don't be like my buddy Tom with 8ft of brake cleaner fire shooting out of a drain hole while you're welding up the pan
WHERE is the crack in the pan?
