Need help Loss of power ??? - Ford Powerstroke Diesel Forum
Old 03-01-2010, 06:29 AM
I am working on this truck. It is not the one in my sig. It is a 2004 6.0L six speed manual with 34,000 miles on it. It drives fine until you shift into overdrive then it develops almost a misfire. It smooths out a little as you get the rpms up above 2400 rpm. It does not seem to do it in the other gears. Any ideas????
Old 03-01-2010, 06:35 AM
A bad injector or two....
Old 03-01-2010, 06:54 AM
my truck is doing the same exact thing but it is a 5r110 automatic. a guy told me it was the torque converter but it has a miss in the motor at a certain rpm
