Need some help!! Puked again and cant find the problem..
Ok, im at a loss. I cant find the problem and Ford cant either. Every so often it will puke just a little like the picture below shows. this was after a 6 hr trip today. i checked it both times i filled up and it wasnt there. When i got home this is what i saw. Ford put a new cap and egr in several weeks ago. They pressure tested it and gave the truck a head to toe inspection and it was perfect.... what is causing this? is my bottle a little to full? is the degas bottle bad? it does not appear to have head problems, they usually puke pretty bad. its at the recommended level with the new sticker. (Might be a hair over) the trucks runs perfect with no problems.. Im a 99,700 miles with 2 egr valves and a oil cooler and egr cooler so far... i just want to find out what the problem is..... HELP!!!!!!
subscribing.. mine sometimes does the same thing, but my egr is deleted. i did however replace my cap with one from oreillys, and i didnt have the residue after an hour drive. lol, but with my truck, it could start next time i crank it up!
this is getting to be a PITA! if its nothing im ok with it, if not i want to get it fixed!!! maybe somebody will chime in!!!!
anyone!!!!
I cant tell by the pic, is the coolant level about 1/2 inch down from the black?
I had the same thing to me about a two months ago. Ended up being oil cooler, EGR cooler, HG.
Make sure you are not overfilled. Level was revised to be lower than marked. Otherwise monitor/test cooling system pressure.
its about half way from the black...
ford keeps checking it... they say its all ok... they are usually pretty good to me also....i dont know?
here is a pic of my sticker, you may be slightly overfilled? not shure. Yes, I have no coolant in my degas bottle, I am puking bad, blown HG for the third time
We are going to fire ring this time.
