??scanner??
06 f350 powerstroke v8
what model/brand scanner do i need and where is the best place to purchase it? |
Welcome to the org, if you were to do a search you wil find that the only tuner for a 6.0 is
![]() ![]() ![]() ![]() ![]() as far as where most will recommend Eric at Innovative or Matt at Gearhead |
I believe he is looking for a diagnostics scanner
If thats the case you want to take a look at the auto-enginuity AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics edit: are you having issues with your truck |
turns over about 15 to 20 times then start fireing for about another 10-15 turns and then runs roughhhhh with the extra loud diesel tap. also stutters alittle under engine strain, like when getting on it to get to highway speed. its a manual shift...
, sorry about that!A friend of mine uses the Matco brand handheld scanner and is very pleased with it...it'll do all the reading and data logging you need and it also has updatable diagnostic programs that run everything from simple on/off tests to full system operations and results. down side is I think you have to by it from Matco or an authorized dealer, like a tool truck. |
