WON'T START, TURNS SLOW, NEW STARTER & BATT'S - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-27-2010, 11:11 AM Thread Starter
crowpeak's Avatar
Exclamation WON'T START, TURNS SLOW, NEW STARTER & BATT'S
I shut the truck off at night, then the next morning it would not start. It was about 10 deg F above 0.
Engine turned over real slow, took off the starter and had it checked, they said it was shot. Got a new Starter.
Still turned to slow to start, replaced batteries.
Still turns slow, like something is dragging.
Any idea's Tech's?
Thanks
crowpeak is offline
post #2 of 20 Old 02-27-2010, 12:40 PM
willislawns's Avatar
Quoted: 14 Post(s)
OIL!! Not sure what you use but I use synthetic in winter. Like 0w 15
2006 F250 CC 4X4
STOCK (EGR Delete)
161k and counting
9'2" Boss V
6 way strobes
Blue spring upgrade
5" after down pipe 6" tip no muffler
Replaced fog lights with led bar
Stage 1 Turbo
willislawns is offline
post #3 of 20 Old 02-27-2010, 12:40 PM
Quoted: 14 Post(s)
Worth a try at least
2006 F250 CC 4X4
STOCK (EGR Delete)
161k and counting
9'2" Boss V
6 way strobes
Blue spring upgrade
Stage 1 Turbo
post #4 of 20 Old 02-27-2010, 12:51 PM
Make sure battery connections are clean and good. Best batteries in the world wont help if the cables are beat.
2008 6.4 f250 lariat 4wd
melmount is offline
post #5 of 20 Old 02-27-2010, 12:58 PM
Lyndsey's Avatar
Send a message via Yahoo to Lyndsey
Check for a draw, plus you should use a 10W30 Rotella.
Make sure your batts are 850 CCA a piece.
Tyler's Truck
1997 F-250 CC LB 4X4
Factory E4OD
TP38 Turbo
Mile Marker Hubs
4" MBRP Exhaust
Torque Converter Lock-Up Switch
XLT Conversion
SPRING 2010: 140AD Sticks, 17* HPOP
"Everyone needs to believe in something. I believe I'll have another beer."
Lyndsey is offline
post #6 of 20 Old 02-27-2010, 01:05 PM
i would check and see what your volts are at the starter first and if its not above 12.4 you have a draw if it is and it still turns over slow i would check your starter realy and jump 12.0v to the starter after that and it turns fater then thats your problem
i am a ford diesel tech so if you have any other qustion fell free to ask
what kind of oil are you running in your truck?
justinbF250 is offline
post #7 of 20 Old 02-27-2010, 01:06 PM
Lyndsey's Avatar
Also, just shut everything off and pull the key out, check voltage on the battery, if anything is over 0.7V then you have a draw.
Tyler's Truck
Factory E4OD
TP38 Turbo
Mile Marker Hubs
4" MBRP Exhaust
XLT Conversion
Lyndsey is offline
post #8 of 20 Old 02-27-2010, 03:56 PM Thread Starter
crowpeak's Avatar
Thanks a lot for the advice guys!!
I will try all of your suggestions and be back later
crowpeak is offline
post #9 of 20 Old 02-28-2010, 03:54 PM
Feedback Score: -1 reviews
check your front accessories (a/c compressor, alternator, p/s pump ect) one may be locked up and causing major drag on the starter. just a shot
fordmasterdieseltech is offline
post #10 of 20 Old 03-04-2010, 03:22 PM Thread Starter
crowpeak's Avatar
Isn't there some way to make the codes scroll accross the dash?
I've checked all I can on this using the help from the posters, but still not starting.
I don't have any way to check voltage......and I am kind of a beginner at a lot of this.
The truck was running good, then when I tried to start it on a cold morning, it turned over real slow. New Starter and batteries since then, but still turninig over slow. I checked to see if it looked like the a/c compressor, alt, and etc was dragging, but they look ok. Thanks for all the help!!
crowpeak is offline
