6.0 egr/remote oil cooler
I love my 2005 6.0
, had the heads replaced and went with the stud bolt upgrade.Very expensive........ About 3000 miles later the oil cooler clogs and causes the EGR cooler to fail again also the turbo was leaking oil . Replace oil cooler EGR again and TurboNot as expensive as the first time but not cheap.......... Questions ![]() 1. Has anybody done the remote oil coolers and is it worth it? 2. Will an EGR delete harm or lower MPG or the performance? 3. How do you reprogram the truck to keep the check engine light off if you do delete the EGR cooler? 4. what is the best synthetic oil to use? |
SCT?
I assume you have to buy a hadheld programmer of some sort.
I am not wanting to race the truck or anything, is it possible to just buy a chip or something that would not have to be re programmed? Last edited by dannyrayfee; 02-27-2010 at 01:20 PM. Reason: clearify |
Not only does the egr delete help mpg it also lowers egt. I go my tuner and tune from elite diesel eng along with changeing the top speed and lots of things. I personally like rotella oil, been running it in my big rig for a long time so I also use in in my ford with good results. Don't know about the remote oil cooler, haven't gotten around to that yet.
Off Road Mag did an article about installing a remote oil cooler that may help you out. Here is where you can find it.
Permanently Fixing a PowerStroke - Off-Road Magazine |
Just found out from dealer my oil cooler and egr cooler are done they want 2600.00....................I think i will do this myself.... any leads on good aftermarket products would be appreciated
we can get you a full EGR delete kit and oil cooler rebuild, you can DIY and save some bucks!!
Thanks for the reply i will check out your site
You may run into problems passing state inspection with a EGR delete
