Hard start and chugging? - Ford Powerstroke Diesel Forum
Old 02-23-2010, 07:24 PM
Now I'm Strokin6.4Liters
Feedback Score: 8 reviews
When I went to start my truck this afternoon to go to class it did not want to start and I had to crank it 5 or 6 times before it finally started. (I cycled it twice before I cranked it) It would crank and start for about a second and then die. It did this every time until it finally started. I have new batteries so its not that. Also I didn't have time to let it warm up completely because i was late for class and when I pulled out it was smoking white and chugging but it cleared up when it warmed up. It has never done this before and i'm just kinda wondering what it is. It was about 45 degrees today also so I don't think it was the cold. I also have a full egr delete so it can't be that. Any ideas????
Old 02-24-2010, 06:57 AM
Feedback Score: -1 reviews
I would start by checking your FICM over rreal good, making sure you have proper voltage. check your fuel pressure as well and change your filters if you havent lately.
Old 02-24-2010, 07:29 AM
How do I check it. I don't have an AE
Old 02-24-2010, 07:44 AM
search ficm repair on here and it should bring up the proceedure to test and repair the ficm. and remove the cap on the secondary fuel filter housing and see if you have fuel in there.
Old 02-24-2010, 08:08 AM
Where is the secondary fuel filter housing at?
Old 02-24-2010, 08:12 AM
Send a message via ICQ to VeeDubTDI Send a message via AIM to VeeDubTDI Send a message via MSN to VeeDubTDI Send a message via Yahoo to VeeDubTDI
On top of the engine next to the oil filter. Similar style housings, but the one for the secondary fuel filter is much smaller.
The one on the right in the above picture.
Old 02-24-2010, 08:20 AM
Thanks. I'll check it soon. Also I have heard swamps sells redone FICMs. Is this true?
Old 02-24-2010, 08:36 AM
Also if i buy a new FICM and have to get it programmed for my truck will that change my strategy and make my IDP tunes useless?
