how hard is exhaust install? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-11-2010, 05:47 PM Thread Starter
i am looking to put an exhaust on my 03. which would is better a 4" or 5" is there any problems installing these. and what kind of results should i see such as in mpg & hp gain
cain6.0 is offline
post #2 of 14 Old 02-11-2010, 05:59 PM
mcflan's Avatar
Feedback Score: 9 reviews
03 6.0 I assume by your name. 5" allows most air flow, but could be harder to put on. I have a Banks Monster and that has a 3.5" downpipe to 4" and it works really well. Maybe 1-2mpg gain depending on how you drive. Horsepower, maybe 10-15 I think? Don't quote me on that.
I found it to be fairly difficult because I didn't have a lift to put the truck on--or ramps for that matter. I had it parked up against my culvert and the biggest issue was getting the downpipe off and past all the firewall. If you don't have a lift, you have to cut the downpipe to get it off (or atleast I did). I would recommend taking out all the firewall crap too, it just breaks up and can cause problems down the line. Should've seen how much of that crap was on my engine and ripped apart.
Good luck
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #3 of 14 Old 02-11-2010, 06:00 PM
kingsntie's Avatar
I found that 5" is not much better unless your going nuts on mods. I did 4" MagnaFlow SS only because I got a steal for it. The MBRP is also great and what I planned on. I installed myself, alone except for getting the down pipe installed and last bit lining up of everything. About 8 hours with several breaks and maybe a beer or two. I cut the old out, loosened the clamp on turbo, slid all out and went to town. Biggest issue is getting the down pipe connected. I also had issues with the bolt at the bottom of the down pipe, just no room to tighten it up. With patience and sore arms I got it. Not sure in terms of extra power as I added my SCT at the same time. Keep in mind you will press the fun pedal more to hear it which will probably get you worse milage. I have run my SCT in stock now that I think and it was a noticable improvement but the SCT gave HUGE difference. If I had help and had the git it done attitude it would have taken 3 hours.
FOR SALE ON EBAY....NO RESERVE...
Truck is in Ft. Lauderdale
2006 F250 King Ranch CC 4x4
68,000 Miles
SCT tuner, no custom yet, run SCT street tune
4" Turbo back MagnaFlow SS, cat delete, 5" TIP
AFE air filter
2" Newton front lift, 1" add blocks for rear
20x10 Helo MAXX8 Chrome w/ Toyo MT's 33x12.5x20
kingsntie is offline
post #4 of 14 Old 02-11-2010, 06:18 PM Thread Starter
i should have told you i do have access to a lift and two good mechanics that don`tcare to help at my work. will it still be a pain with the 5" & how much turbo will i here oh yeah and i already have tuner on it i really don`t hot rod it much i just like hearing that turbo
cain6.0 is offline
post #5 of 14 Old 02-11-2010, 06:21 PM
mcflan's Avatar
In my opinion, I would just stick with a 4" DP. Just my .02
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Isspro Gauges
175cc Injectors
Powermax Turbo
Blue Spring FPR
AD2 Fuel System
Oil By-Pass System
mcflan is offline
post #6 of 14 Old 02-11-2010, 06:23 PM
Raging Lunatic
choctaw's Avatar
Even if you go with a 5" system the downpipe will only be 4", that's all they can physically fit in there.
Unless you're going to be making over 500 HP I would save my money for other mods and go with a 4" system. Sometimes bigger is not better.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #7 of 14 Old 02-11-2010, 06:28 PM
Turning diesel into noise
1693Cat's Avatar
You tube it!http://www.youtube.com/watch?v=Uy_0dHhjgtk (Not my truck in the videos) It whistles like a Peterbilt with a Cat and rumbles over 2000 RPM like the 428 I had in my old 76 F250
1693Cat is offline
post #8 of 14 Old 02-11-2010, 06:29 PM Thread Starter
you made my mind up for me. thanks fellars hey mcflan that turbo sounds pretty good
cain6.0 is offline
post #9 of 14 Old 02-11-2010, 06:34 PM
kingsntie's Avatar
Choctaw is right IMHO. 5" would be a waste, just cool to tell and post in a sig, the dp would only be 4" anyway. I hear a decent turbo at idle but have found the muffler kills the whine you are looking for. I still have my muffler but plan on taking it out to get that killer turbo sound. Heard a straight pipe like mine and the whine was much more than me. Search youtube and most important, ask people when you hear one you like. They usually would tell you all you want to know about their truck.
68,000 Miles
AFE air filter
post #10 of 14 Old 02-11-2010, 06:36 PM
Raging Lunatic
choctaw's Avatar
That sounds just like mine with a 4" TB.
ΜΟΛΩΝ ΛΑΒΕ
choctaw is offline
