6.0 oil pump gear blows for fourth time - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-05-2010, 12:43 PM Thread Starter
Hey guy, I have had the problem of my oil pump gear on the crank blowing up on me four times. once a 30,000 again at 61,000 then 66,000 which is when they put a short block in. Now im at 100,641 and it happened again. If anyone else has had or heard of this I need to know fomoco blows smoke at me and says im the only one this has happened to. It's B.S. any help would be great so i have some backing when they try and tell me its the way i drive. cause its not i drive big trucks at work all the time i know how to shift. I went through the FORD ASSET program, i worked for the dealer that i bring my truck to. i know what im doin when it comes to engines.
stacked06 is offline
post #2 of 7 Old 02-05-2010, 01:16 PM
Feedback Score: -1 reviews
are they telling you that you over-reved the motor which caused the pump to come apart?
fordmasterdieseltech is offline
post #3 of 7 Old 02-05-2010, 03:16 PM Thread Starter
no they are not telling me that. they dont know what is causeing it. im thinking something like a balancer or fly wheel that is just a little out of balance. making the crankshaft walk and therefore makeing the gear blow into little peices. I have no vibration that im feeling, seeing how your a tech i could give u the vin an you run oasis n that will give u history on it. i was a tech at one time n decided it wasn't for me.
post #4 of 7 Old 02-05-2010, 07:27 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
The only way I could conceive this to be possible, would be excessive crankshaft thrust end play, but that would also cause the crankshaft to "walk" enough to lose CKP SYNC, and in your engine to stall.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #5 of 7 Old 02-06-2010, 04:35 AM
Powerstroke Techie
If it's breaking the oil pump, it should be getting a front cover when it does so.
Has the front cover been replaced? How about the cover over the pump itself where the seal mounts to?
Check crankshaft endplay. Is your truck a manual or an automatic?
Can you post up pics of the busted gears so we can see how they're breakin?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #6 of 7 Old 02-06-2010, 05:46 AM Thread Starter
I understand what ur sayin m-chan, but again it take 30,000 for this prob to happen again. Yes the front cover has beeen replaced 4 times and when it got a short block all my old externals were reused. the truck is a stick, i know how to drive the truck i still have not put brakes on the truck it has 100641 miles on it. i know they are goin to try and point to me being the prob. i will post pics of the first time the gear blew when i get home to my own computer.
post #7 of 7 Old 02-06-2010, 06:37 AM Thread Starter
Sorry guys just looked up my records this is the first time it happened at 39,594 then again at 61129 then again at 66104 which is when they put a short block in and now at 100641.
