Techs, do I really need the special socket to remove IPR valve? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-05-2010, 08:42 AM Thread Starter
The manual says I need special socket, no. 303-1112 or ST2859-A to remove my IPR valve ('05 6.0). Is this true, or can I use something else? If I can cut down a socket, what size? Three Ford dealers around me don't sell tools, and those numbers don't come up with anything in Snap-on or Mac searches. I am also looking for part number 303-765, which is an adapter to plug into the ICP hole to adapt to an air fitting.
Thanks in advance.
Lakeside6.0 is offline
post #2 of 8 Old 02-05-2010, 01:42 PM
Feedback Score: -1 reviews
yeah rotunda offers a special socket to remove the ipr. there is a 6 point and a 12 point verson. big pair of channel locks or ive seen people use a sharp chisel and tap it around til its loose and then spin it out.
fordmasterdieseltech is offline
post #3 of 8 Old 02-05-2010, 02:41 PM Thread Starter
An update...
I guess the factory version of that tool runs about $200 and up if you google it. Thats a lot of money for one socket I hope to use once. I bought the IPR valve, and it is 35 mm at the nut. Sears didn't carry anything that big, so I went to a Harbor Freight Tools. Don't worry, I wore a disguise. I found a set of deep impact sockets for axle nuts that was $40 for all five sockets. I will have to cut a groove for the electrical connection, of course, and possibly grind down the diameter if it's tight in there. Channel locks and such don't seem a viable option unless I remove the turbo, which I shouldn't have to do if I use a socket.
As far as the adapter for the ICP sensor, that comes up at $66 if you google the numbers. Still a little pricey for a one ounce fitting. On another post someone said go to a hydraulic shop for an adapter and gauge, but my local hydraulic shop said it is not a standard fitting of any type. I may have to forgo the air pressure test of the HP oil system.
post #4 of 8 Old 02-06-2010, 05:41 AM
Powerstroke Techie
Depends on how much you want to take apart.
You can do the IPR without removing the turbocharger if you have the proper socket. If you make your own out of a spindle socket, you will not likely be able to get it to fit with the turbo/intake/etc on.
What I would do, if I was you, take the turbo off and use a wrench. I believe it measures out at 1-7/16" if I remember correctly.
As for the tool to air the system up, I have another suggestion for you. If you're going to have the IPR out, turbo off, I would put the updated one-piece STC fitting kit in it while you're there.
The reason I say this, is because in this kit comes a small chrome plug that you can drill a hole through and fabricate your own air-leak tool out of. That little plug screws into the top of the HPOP, but the thread pitch and size is the same as the ICP sensor in the valve cover.
Alternatively, you could take your ICP sensor to plumbing shop and see if they can match 'er up.
Hope this helps.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #5 of 8 Old 10-25-2010, 06:30 PM
If there is anyone wondering the thread size of ICP sensor off of a an 07 is 12mm x 1.50mm. I am assuming that it is the same for all the 6.0ls.
2007 F-250 Lariat FX4 crew cab
RNJARMAN is offline
post #6 of 8 Old 07-03-2015, 12:38 PM
I was almost discouraged by reading this forum and looking at the price of the tool.........then I got it out with out removing the turbo or a special tool a couple a long and a few short wobble head extensions and a 1@3/8" crows foot and bang got it..... found a missing screen and a chunk of green o-ring in the IPR.... you could probably use a 1@3/8 socket and cut out a channel too.-Dave Newman RCEME arte et marte
DaveRceme is offline
post #7 of 8 Old 07-03-2015, 08:30 PM
Quoted: 20 Post(s)
I bought one at Princess Auto up here in Canada for $10. Used it a few weeks ago and it worked like a charm. I would have to imagine you could find one in the US similar to the Princess Auto one and price.
Shim is offline
post #8 of 8 Old 07-03-2015, 08:33 PM
ZMANN's Avatar
Quoted: 1355 Post(s)
this thread is six years old the sockets are cheap now
We Miss you Ronnie
ZMANN is offline
