Bed Plate Seal
Has anyone had this seal replaced, and if so was there truck ever the same after they put the truck back together? I am having second thoughts about this repair the oil leak is not that bad. It only drips once or twice a week.
if its done right you wont have any problems , i have had people decide not to do it though , ask to talk to the tech about it , that way you get e feel for what he knows ,and you usually can tell if they know what there talking about
I had mine done about a month and a half ago. No problems since. The truck runs just as good as it did prior to the work and no leak! I had second thoughts at first but after a long conversation with the tech that would be working on it, I felt better about having it torn apart. He also requested that I stop in from time to time to check things out during the process. FWIW, I am glad I had it done.
I passed on the same issue. Upon talking to the service manager and hearing what the tech thought I decided to live with it. I have faith in the tech, tearing down a low mileage engine that runs perfectly is not worth it with a small 2 drip leak. I was told that it will not get worse, and if it sludges up a little it may stop. ( OK, I hear the groans,good luck with that, Rattlebox!) I have 3 years left to go on the warranty, I am going to wait and have it done if I have a larger issue.
the biggest thing with a bedplate leak...is to be ABSOLUTELY sure that is the leak. It is a major job, and if a well qualified tech does the job there should be no negatives...BUT......
bed plate leaks are often mis diagnosed...often times they are a cam, or crank sensor....or are a leak that is dripping back from the seam between the bed plate and block that is coming from somewere else. This is absolutely not to say they dont leak...but its not common....ESPECIALLY in a motor that has never been touched...the most common cause for a bed plate leak is an improperly done front cover or rear cover removal. if you dont cut the silicone before those jobs you risk streatching the bed plate gasket... |
So Marc I have had the same issue with mine as you may already know. they changed the rear seal twice and now they believe it is the bedplate. It only has 10k on it and i am starting to feel like rattlebox about mine. Besides the rear seal being changed, nothing else has been been done to it. No other engine work. In your opinion do you think they advised him right? If you were in my predicament would you have the seal changed or not? Thanks!
Thanks for the repy Marc, it is greatly appreciated!
no problem buddy
Thanks for the thumbs up! (and I feel better about my decision too!)
