6.0 Turbo Problems
Hey guys,
Has Ford come up with a solution to the turbo problems with the 6.0 Turbo engine? Does anyone know what's causing these failures? Does Ford? Sounds like they don't want to fix the problem - just give you another turbo and send you on your way. Your thoughts would be greatly appreciated. Michael |
the turbo is not a bad design , most of the problem is most people do not use the turbo thru its full range enough and causes it to stick, never see a turbo problem with a heavy vehicle such as 550 with a crane or something because they are using that turbo thru its full range all the time ,sunday driving is the problem we see with most turbos , or people that have a second vehicle and never drive there truck all the time so therefore the turbo sticks, then they hook to a trailer to go to the lake and it wont pul good cause the truck has sat for a month , turbo stuck
I don't see this as an issue ...we are running F-350 ambulances and we have replaced two turbos. If you research...it appears the design from Ford is causing increase heat build up which causes these to fail.
excess idle time builds carbon in them as well.....increased heat would actually help these turbos.....also....ford doesnt design or build the turbo, garret does.
can you tell me what your recommendation would be then... obviously we have long idle times..in some cases. Off often do we need to tear these down to clean them out ?? Anything we can put in to help break down this carbon? Any other recommendations would be helpful. Thank you.
another thing that would help is putting in a high idle controller....anytime it idles for an extended period bump it up to high idle and that should help it as well..... |
thanks marc for seeing it the way i do first , second all the ambulances we work on generaly have high idle mode when accessories in back are on
I've heard people say that if you really floored it about once a week (say while merging onto the freeway), that this is a good way to burn out/clean out all the carbon. Would this help me to minimize any future problems along these lines with my turbo? Jerry |
