starting issues - Ford Powerstroke Diesel Forum
Old 01-11-2010, 04:21 PM
starting issues
starting happening bad today. will try to start it, will go to about 200 rpms then die. happens 4 or 5 times then will finally start. runs fine after it starts.
any ideas?
Old 01-12-2010, 02:01 AM
Check your FICM
Detailed FICM Repair Procedure
Old 01-12-2010, 06:12 AM
if my trucks still under the 100k warranty is this covered?
ill check the voltage later today on it and get some help fixing it if its not a warranty item
Old 01-16-2010, 11:13 AM
just checked my ficm. shows 48.6 so its not bad. any other ideas?
Old 01-16-2010, 11:20 AM
had same problem with my '06 f250 (has 263k miles) bad ICP cost $363 to have it checked and replaced at dealer. also had the latest reflash. starts way better
Old 01-20-2010, 05:45 AM
so yesterday the truck broke down, finally turned over after about 30 minutes and got it home. dropped it off at Powerstroke magic last night, turns out its a bad EGR, and 2 dirty sensors they are going to clean up. theyre weldin off the egr for me.
Old 01-20-2010, 08:55 PM
got my truck back. running much better, and im not throwing any codes which im suprised about.
