puking again - Ford Powerstroke Diesel Forum
Old 01-09-2010, 08:12 AM
puking again
hey guys this is my first post in forever. hope all is well over here. my truck is spitting coolant from the degas bottle again. it has studs so im thinking maybe oil cooler. it does this when towing on stock tune. i have a livewire but cant get it to read the oil temp, or at least i think its not working. it will read something like 12037.0. not sure what this is unless the dot is in the wrong place. then it would be 120.37 then when changed to F it would be like 250. can anyone help with this?
Old 01-09-2010, 08:15 AM
also thinking of changing my rear diff temp gauge to oil temp. where is the best place to install the sensor?
Old 01-10-2010, 08:03 PM
Mine was doing the same thing when towing my 14000lb 5th wheel. I have the studs too and when I took it back to Ford it was the oil cooler. Im going to delete the egr next. Hope this fixes the problem.
Old 01-10-2010, 08:05 PM
You need to monitor EOT and ECT and compare the two. They should be no more than 15* apart
Old 01-11-2010, 01:43 PM
yes, im trying to get this sct livewire to give me an accurate oil temp reading but not having much luck.
Old 01-29-2010, 02:39 PM
Injector sleeves. There is a TSB on this.
Old 01-29-2010, 02:49 PM
Shaking the Bush Boss
ncbowhunter
come on over to the CPA chat thread! Welcome to the org........
Old 01-29-2010, 03:52 PM
What's the adress?
