Turbo problems ?
2K views 2 replies 2 participants last post by  Norwegian Viking
#1 ·
Hello
I have F250 6.0 2003
When i start engine, the turbo do not spool up beafore i been driving som meters.
And when its cold like in Norway now, i start up engine, and let it run to get temp, but turbo do not spool up beafore after 1-2 minutes.
Is this normal, ore is it som problems whit a walve on the turbo ?
I also seem to have som problems whit the alternator, it sems that it do not chards so good when alternator get hot.
Is this enything that you guys know about ?:dunno:
Norwegian Viking
#3 ·
Ok tanx
To bad i diden clean the turbo inside when i did the EGR blocking on it :doh:
Then i have some more work to do :tard:
Norwegian Viking
