Blown Head Gasket Codes?
Does anyone know the codes a 6.0L throws when the hgs are blown? My truck spits and sputters like it is loosing fuel. While it was doing this it threw the code 0266 (Cylinder 2 Contribution/Balance Fault). Whould this be the hgs or something else like an injector? thanks for the help!!
Head gaskets do not have electronics in them! cct code is most likely a injector.
I realize this, I just wondering if it caused any other codes to be thrown.
Not usually! Because it is mechanical failed part. But an injector will cause your problems. Have you had it on a scanner?
No codes for head gaskets. That code you listed is a bad injector. The only way to be able to tell if the gaskets were gone is to have a pressure gauge on the coolant system.
I think i had a code like that and one of my infectors went out. check out your injectors
