6.0 firing order - Ford Powerstroke Diesel Forum
Old 01-03-2010, 02:54 PM
6.0 firing order
Just had 3 inj. replaced 1, 6,and 7 run like crap. my buddy lost 5 inj. his ran smooth but lacking power just like my.
Old 01-04-2010, 01:14 PM
6.0 fireing order is 1-2-7-3-4-5-6-8
Old 10-18-2010, 05:33 PM
On my 06 6.0 why would all my glow plugs not work. I had to change the computer and one injector and now the only code that comes up is 1 threw 8 glow plugs not working.
Old 10-18-2010, 05:58 PM
I'm gonna guess the injector you replaced was on the passenger side...
Old 10-21-2010, 04:46 PM
yes it was. Passenger side
Old 10-21-2010, 04:47 PM
Yes it was anyh idea??
Old 10-22-2010, 03:32 PM
Did you check to make sure your Glow Plug relay was plugged in?
Old 10-23-2010, 01:07 PM
If the glow plug relay is found on the passenger side valve cover and has two plugs yes. I even changed it with another one i had. I had taken the the ficm and switched it out to match the other relay also. I did some research a couple of nights ago on th Ficm and found out that the one i originally had and the one i changed it with were both out of a 03 and this truck is a 06. I also found a place that will rebuild the ficm for $325 in 48 hours but the one i have isn't the correct one. Any ideas?
