cab on studs
Can you install head studs one by one with out removing the head I have no head gasket problems but want to install studs to keep it that way.
Not with the cab on. You wont get the outside, rearmost bolt out, nor get the stud in without taking the head off. When I first looked into doing studs, I called a local diesel shop, and this is how they wanted to do mine (cab off, swap one at a time). I didnt feel safe doing it this way. Good thing I did it my way (cab on, pull heads). I had one gasket that was beginning to fail in three areas. Along with white spots on 4 pistons.
It seems like that is playing with fire on an engine that is known to have issues in this department. |
