Puking Coolant - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-30-2009, 02:49 PM Thread Starter
RobertCgdll's Avatar
Puking Coolant
My truck just started to puke coolant. I am getting an egr delete from RCD. Does the oil cooler need to be replaced? And can the heads be damaged? I dnt have the money for the heads right now. I plan on doing the delete my self. Is there any thing I need to look for? Thanks
2007 F250 Xlt 4wd
aFe stage 2 intake, 6" Aussie stacks, Sct X3 (Erics tunes)
RobertCgdll is offline
post #2 of 4 Old 12-30-2009, 03:05 PM
Powerstroke Techie
Oil cooler needs replacing if the EGR cooler has failed. Look at ECT and EOT and beat on it -- if the oil temp exceeds the coolant temp by 15*, the oil cooler is restricted and must be replaced.
Yes, heads may also be damaged.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 4 Old 12-30-2009, 03:46 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
After warmed up running fine my ECT and EOT sometimes run just about the same temp usally see no more difference than about 15 degrees.
When towing I can get as much as 30 degrees when it's hot in the summer and pullin a big hill. So my ? Angry Hillbilly is looks and sounds fine to me but when I do my egr delete this spring should all I have to do if temps stay the same as present is just put a rebuilt kit in my oil cooler and maybe tank, wash out the exhaust manifold???
Thanks
Jer-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #4 of 4 Old 12-30-2009, 05:52 PM Thread Starter
My trucks EOT usually stays at 195 and may hit 200, I dont know what the coolant temp is though.
2007 F250 Xlt 4wd
