oil in the intercooler/leaking turbo?? - Ford Powerstroke Diesel Forum
Old 12-25-2009, 11:40 AM
Is there suppose to be any oil at all in the the pipe coming off of the turbo.I found oil in the pipe, the intercooler and the intake. Is there a seal or o-ring on the turbo that can be replaced and is it hard to do. It is a remanufactured GARRETT TURBO. 2007 F350 6.0, K&N INTAKE. 67000 miles.
Old 12-25-2009, 08:59 PM
oil in cooler system is normal
Old 12-25-2009, 09:15 PM
not to hijack or change the sub but sportsman 500 i've been to whitefish and thats the nicest part of the country i've been in. i'm jealous, must be great to get up every day and see that part of the country? my wife says we need to go back and i agree.
Old 12-26-2009, 06:51 AM
yeah i like living in this part of the country , used to live in new jersey , what a change
Old 12-26-2009, 06:57 AM
is the cost of living reasonable?
Old 12-26-2009, 07:14 AM
if your concerned about it then reroute the ccv to a catchcan somewhere else in the truck, preferably along the framerail
Old 12-26-2009, 07:46 AM
A little more info
As previously stated some oil is normal, useually sucked up from the CCV filter
(crankcase ventilation filter). In older vechicles its where the PCV valve was mounted. This is a wire mesh filter and as any filter needs cleaning some times
When saturated oil can be sucked into the intake.
On the 6.0 this is externally mounted on the front drivers side valve cover, connected to the bottom side of the plastic houseing mounted between the air filter and the turbo by a short molded hose. This can be rerouted to discharge into an external can which will need to be emptied perodically.
As stated some oil is normal an excessive amount can indicate worn/broken rings leaking combustion gas into the crank case.
Old 12-26-2009, 08:06 AM
Is there any smoke?
Old 12-26-2009, 11:58 AM
thanks for the info. no smoke, now do I need to clean the intercooler from time to time and what is the best way to do that.
