Ok heres the scoop.. batts new 2 mo ago, had the first big snow storm two weeks ago and i was out pushing snow..it was about 230am the night of that crazy blizzard we had here and i noticed my lights were getting dimmer and dimmer when i would use the plow..well i plugged in my SCT and it said my batt volatge was around 10.9s 11.2s YIKES! so i assumed my 110A alt was taking a crap from all the abuse so i headed for home..
well the entire area was shut down from the storm and i needed the truck fixed quick so i just made my way to the parts store and forked over 210 bucks for a new ALT.. got it on the truck and voltage was around 13.9s consistantly.. so i figured problem fixed.. well finished up the storm and i started droping voltage again!! I then started looking into the wiring on the plow..i noticed the solinoid for the plow was getting really hot over time after using the plow.. so i took it into the dealer and the guy recommended a new solinoid and told me to clean my batt cable ends as they looked corroded.. so i bought a new heavy duty solinoid (updated version for the plow) and i took every whire off and brushed them to a shine and re-installed according to the digram for the plow.
well i also realized i had bought another 110A alt when i really wanted the 140A alt.. i went back into the parts store to get a 140A to help with the extra load from the plow..luckily they let me return the 110A and i bought the 140A for the truck..for some stupid reason it was $40 cheaper
so that was about 2 weeks ago and everything has been just fine on the truck.. (plow off) well i put the plow on this AM in prep for the storm coming in..made sure all the controls worked since the new solinoid and everything was fine.. well driving home from work i got about a block from home and noticed my Batt light was flickering on the dash..when at idle it would come on more and as i accelerated it would fade out and flicker less..plugged in the SCT and it was reading 11.2s voltage.. (bear in mind the plow was not used today..just hung there in the off position while driving..)
obviously the plow is the number one culprit, but ive checked all the wiring for shorts etc. and everything is good.. What else could be sucking the life out of my batteries??? sorry for the lengthy post but im at a loss and need to get this solved FAST! thanks!
