High pitch noise?
I have a high pitch noise coming from my engine compartment at high rpms and high boost. It recently started and has gotten worse since the other day when I upgraded to an extreme tune from innovative. My coolant level is good and doesnt seem to be overflowing. Does anyone know what could cause this? Please dnt say head gaskets
. thanks for the help guys. Oh and im going on a 1000mile trip on the first so this is urgent.
as you say high pitch noise, describe further, does it sound like a screech? tea kettle? do you smell heavy exhaust in the cab?
Its not a screech and no exhaust smell. Kind of like a tea kettle or an extremely high pitch turbo wistle
I just drove my truck on the highway and got it up to a constant 2000rpm. I layed on it a little and the boost went to 29 and the noise popped up. I did it again and it happened at 29psi again. once I let out of it it immedialty stops. What could this be?
hole in boot maybe ??
sounds like you got a boost leak.
my truck is doing same thing it the sound is coming from the air box i mostly hear it when i let off the throttle or the auto trans shifts
it will be going in the shop next week for a check engine light ...code says its a bad exhaust pressure sensor i will have them check out the sound also |
update ..... stopped by the dealer today and spoke to the diesel tech , he said that there is to much pressure in the coolant system he should know more by tomorrow ,,, i hope they get it fixed fast because i miss my truck
i don't know if anybody is still following this thread but i will update for the search engine
update dealer called today , looks like it is a head gasket that is causing the issue ,, they said that the cant repair until 1-18 ... thats a long time to go without a truck |
Does it do it a lot more the colder it is? Mine will do it going from 0-20 in a school zone just on the backside of a shift when it's really cold.
Once the truck is warmed up, it won't do it as much and primarily on a heavier throttle/increased boost. Tea kettle is the best description. |
