6.0 headache - Ford Powerstroke Diesel Forum
Old 03-26-2007, 11:13 AM
6.0 headache
I,m new to the forum myself. Had simular problem with '02 and replaced fuel pump, runs fine now.
I have problem now with '05 6.0 that put head gasket on and now shows no oil pressure and want start. Can anyone give me some advice?
Old 03-26-2007, 07:15 PM
There you go Samuel, you now have your own thread, I'm sure one of the techs will be along to help with your problem, good luck.
Gord.
Old 03-26-2007, 07:21 PM
Jon
Guest
Posts: n/a
No start
How long have you cranked on it. After opening the oil system sometimes it takes up to 1 - 2 minuets to get it to fire. I have seen some take longer then that.
Old 03-27-2007, 05:43 AM
6.0 headache
>>> Finally got it to start. Did not know proper way to bleed oil system so I
>>> improvised. Took sensor out of valve cover and pulled a vacuum,
>>> itworked. Now Ijust want to know of any other things needed to be
>>> checked after this repair, installed new radiator, hoses, thermostat,
>>> and fan clutch.
>>> Oh,by the way, this is not a personal truck. It is an ambulance that
>>> does across state transfers.
