2003 6.0l ICP Replacement??
My truck turns over good (new batteries) but it will not fire. Sounds like it may want to fire but it won't. If an ICP sensor goes bad,will the engine still try to start or will it just turn over?? Anyone know? Engine has 200,000km and the ICP has never been changed. I have the back cover off already and I can barely see the sensor but it looks like it has leaked before because there is dirt all over the end of the connector. Any tips on wrench sizes and how to get it out would also be appreciated.
A bad ICP will cause a no start but so can a bad HPOP. Do some searching on here. There a handful of threads on this topic.
Snapon carries the special socket that is needed but rather exspensive. I looked in the last OTC catalog that came in to the shop and did not find one , seems they would have one tho. I think its like 32 mm. but it would need to be cut off or the intake removed for ya to use a regular wrench.
i use a 1 1/16 12 pt crows foot socket,works well for me
Ok thanks for the help guys! Someone said something about cutting an inch off of a 1 1/16 deep socket..?
Also,I seen a video of a guy that had a bad FICM going on his truck. It sounded just like mine prior to it not starting at all which is the case now. I took the plug off the ICP sensor and there was a little oil in there.That might explain my intermitent miss going down the hwy. I tried disconecting the icp plug to see if it would start and run in a default mode but no luck. It sounds like it's barely firing and there is a little black smoke coming out the pipes if I crank it long enough. Hope it's not dusted!! Last edited by DieselJuice; 12-18-2009 at 08:03 PM. |
ya thanks M-chan-68. I did get the harness too. Is it hard to splice in those wires?? I hope the harness comes out where I can get at it a little more.
also,my truck does fire a wee bit and there is some black smoke coming out the pipes so wouldn't that say thta some of my injectors are firing? |
Ok got the ICP in...I took a 1 1/16 wrench and cut down to about 3 inches long.Used the box end and it worked great. I removed my front drive shaft and the transmission cable from the trany and tied it out of the way. Took the heat shield off.Three bolts for that and then I R&R'd the ICP. Not to bad of a job now that I have some experience but really,what were these guy's thinking putting in that spot?????
Now I will tackle the wiring. Let you know if it starts or not.....fingers crossed....... |
Play by play action here...lol I unbolted the coolant resevoir and pulled it towards the front of the truck,Unbolted the FICM and removed the FICM bracket thta's attached to the valve cover. Much much easier to get at the wires for the ICP.
It looks like the sensor has been replaced before but it's not the same colour wires as this new updated kit. There is another sensor I unpluged right beside the ICP. Is that the IPR sensor?? |
