edge+06E17 question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-25-2007, 06:34 PM Thread Starter
DoubleDpsd's Avatar
edge+06E17 question
03' 6.0L w/70,000 and clean oasis is the truck in question. Truck has two piece 4" downpipe to a 5" tip, edge juice w/in cab attitude adjuster, and afe stage 2. Truck was flashed with 06E17 while edge was plugged in after oil change and tranny flush was performed at local ford store dealership. Service consultant told me that you couldn't flash a truck with this flash because of the edge and if they did flash it the edge would completely stop working. Couple weeks after flash truck throws p132b and p0603 kam error. Found ford powerpoint demonstration online that states p132b only exists AFTER this flash. After picking truck up from dealership I noticed turbo cycleing/vgt learn taking place. This is very distinct to me and no questions to me as to what it is, because of exhaust set up. Q's: Can they flash the truck with the edge installed? Could the reliance on the maf or map sensor, not sure which one is in intake manifold, be causing p132b to be thrown because afe's kit moves the sensor? Should I get an update from edge to work with 06E17 and hope p0603&p132b go away or unplug edge and batteries? Am I being completely lied to by the service consultant? any opinions, thoughts or comments greatly appreciated. thx guys.
DoubleDpsd is offline
post #2 of 7 Old 03-25-2007, 06:50 PM
Raul@Stealth Automotive's Avatar
i have no clue but ill bump this to the top so that hopefully someone can help you out...
Raul@Stealth Automotive is offline
post #3 of 7 Old 03-25-2007, 07:30 PM
dustindiesel's Avatar
i dont think u will get any updates from edge being it is a generic programmer for a 6.0..if it was a custom burned tune it would be different.
i dont think it would hurt the unit reflashing it- but they prob just didnt want the responsibility of something happining to ur edge unit and having them reinburst you..thats what im thinkin
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #4 of 7 Old 03-25-2007, 08:55 PM Thread Starter
DoubleDpsd's Avatar
thank you sir.
What would you suggest doing to get rid of codes? What would you do if it was your truck? thank for the input any others is greatly appreciated. take care.
post #5 of 7 Old 04-08-2007, 07:19 AM
SMOKE ROLLER
Rescuediver's Avatar
You may want to contact Edge and see what they have to say...
TERRY
BIG RED - SOLD
4" SILVERLINE TB
SCT w/Edge INSIGHT
6" Superlift w/ 37" TOYO'S on 20's
Accufab Elbow
Lots of Recon Lights
HID Headlights & Foglights
Train Horns
SNOW H2O/Meth
Rescuediver is offline
post #6 of 7 Old 04-08-2007, 08:25 AM
straycat's Avatar
You could try the disconect, and run it for a bit without the Edge and see if the codes come back, and if not, try the edge again and see what happens. At least you would know where the problem lies that way, and work from there.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #7 of 7 Old 04-08-2007, 07:06 PM Thread Starter
DoubleDpsd's Avatar
Gord.
thank you Gents. After unplugging the edge and battery that got rid of the P0603 pcm kam error dtc. The edge is still installed on the truck just not plugged in. I still have the pesky P132b though. Im thinking the code is being set by the massive amount of airflow due to afe 2 and downpipe with NO cat and NO muffler, I'll be installing a cat this week to try and create some restriction. the P132b CEL goes off and on on it's own. truck runs great.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
