Oil leaking around exhaust manifold bolts
Why would I have oil leaking around the exhaust manifold bolts? Just had a new head, head gaskets, and ARP's put on and I KNOW it was done right! Is this common or should I call the tech that did the work?
Well this could be residue from pulling the heads but if it continues more than a couple of days I would suspect a damaaged injector tip.
I have found in most cases that it is actually diesel that is leaking, with dissolved oil and carbon it will look like oil,it will just be thinner. |
I've had several small oil leaks repaired so I've been checking from time to time. Heads were done in August I believe, I washed the engine and under carrage down afterwards. Went under to install my new block heater cord yesterday and I noticed oil on the trans lines, starter and on up the side of the block all the way to the exhaust manifold bolts. It appears to be wet around both top and bottom bolts on each cylinder. Didn't check the drivers side cause it started raining.
Would the bolts require a thread sealer, do they thread into an area that would contain oil?
Not useually. By the way do you seem to have a lot of crankcase pressure? You can check this by takeing the oil fill cap off and feeling how hard it is blowing. It should be kinda gentle if it is comeing out hard you have rings blowing by.
There is a tool to check but just feeling listening will useually tell you enough. |
while running
The glow plug harnesses have orings to seal them. Its possible they are leaking.
Oil leak
Thanks again, Chris |
my 04 was leaking out of the oil cooler housing in the Vally of the engine and running down the back of the heads to the trans lines... i thought for sure it was glow plugs or valve cover gasket but it was the oil cooler housing...
