Electrical System Problem - Ford Powerstroke Diesel Forum
Old 12-12-2009, 12:04 PM
Exclamation Electrical System Problem
6.0 Electrical System
Any help would be much appreciated. I am going crazy.
Old 12-13-2009, 02:02 AM
Parasitic draw
First off are you shure you are hooking up the alternator wireing correctly?
Things blowing up or burning out is useually a sign of crossed polarity or a dead short in a big wire.
Assumeing all that is correct take a negative battery cable loose and hook up a DVOM meter or a amp meter in between the post and the cable, there should be no voltage/amps shown with the key off. If there is remove 1 fuze at a time until the reading goes away, put the fuze back in after each reading. This will isolate which circuit has the draw. Then trace out the wireing for that circuit, looking for shorts or open circuits, or a device left on.
A lot of work but the quickest method I know of.
Old 12-14-2009, 09:04 AM
Thanks for the response. I was getting nervous there was a short somewhere but your response defiantly would have helped! It ended up being I bought a bad alternator and was able to return it and get one somewhere else. 200 bucks and running good! Now I don't think the charger blew, but some how it blew the outlet in my timer (the one I use for the block heater). But I returned it anyway. So that's that!
Old 12-14-2009, 09:11 AM
glad ya got it solved
