2004 to 2006 motor swap - Ford Powerstroke Diesel Forum
Old 12-12-2009, 09:51 AM
I have a 2004 f450 I had to get a new long block, so I found a 06 motor it came with everything, installed it and now they say its not going to work. Has anyone swapped out an 04 for an 06 motor.
Old 12-12-2009, 10:42 AM
Early '04?
Unless you want to go about modifying the wiring harness, it will not work. Keep in mind the ICP sensor is on the HUEI pump on the '03-'04's, but it on the pass. side valve cover in the '06. That alone will cause issues.
