6.0 misses sometimes badly
Morning all lately my 04 f-350 w/6.0 runs so bad when you first crank it up that setting in the truck it feels worse that our 428 with a cam in it. I hear alot about injectors going out is the begining of the downhill spirial? Any and all help appreciated, Thanks.
It could be your FICM, read the following, you can check the output to see if it is working ok,
http://www.powerstroke.org/forum/6-0...procedure.html |
switch to 5w40w syn rotella and get some hot shot secret,my 6.0 was doing the same thing ,and the oil fixed my rough starts immediately.the hot shotts cleans the inj,comp fix for 150 dollers,the dealler wanted to put new inj for 3000.good luck !
my 04 got worse and worse when starting it and couldnt even drive it for 15 minutes. really rumbled bad. Went and had the newest flash done last week and its all better. Amazing. i thought my injectors were bad but i guess not. The flash is for cold starts. Try it. Its about $100.00. I can take off now after a few minutes and it idles great at start up
check this thread
there is another thread going about this here:
REV-X Oil Additive |
