HELP - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-09-2009, 04:33 PM Thread Starter
HELP
Hello, i am new here... i have a 06 f-350 that has 52,000 miles on it, i have an edge programer, MBRP exhaust and K&N intake. im having a problem, when i get on it for a little bit (the throttle) then let out of it. and when i go to get back on it theres nothing there..... the engine doesn't rev or anything, the truck still runs and drives....??? i have no idea any help?? could it be my waste gate?? im not a diesel expert at all....so what do you guys think!!!!
tmd1029 is offline
post #2 of 4 Old 12-09-2009, 04:35 PM
alfajay's Avatar
have you tried removing the programmer and seeing if it still does it?
2000 F250 XLT SC 4x4
4" T-back MBRP 5" Tip--Quad Commander--DIY Intake--Foil Delete--Zoodad--AIH Delete--CCV Mod--Wastegate Disconnected--Drilled & Slotted Rotors--Smoked Headlights/Corners--OEM Alum. Diff upgrade--TW Tuned--WW/EBPV delete--RECON White Lightning
2006 Ram 2500 QCSB--Debadged--Silverbullet--180 sticks--Modded CP3 & Rail--Manifolds--AFE Intake--FASS--Studded--Trans~clutches, VB, Billet Input, Billet Flexplate,TC--Smarty--ISSPRO Pyro, Trans & Boost--Quad FP & RP Dyno-631/121*
alfajay is offline
post #3 of 4 Old 12-09-2009, 04:38 PM Thread Starter
No not yet... But this just started to happen.... i had the programmer on the the truck since 07...
tmd1029 is offline
post #4 of 4 Old 12-10-2009, 07:26 AM Thread Starter
okay took the programmer out last night and drove to work this morning and still does the same thing??? ANYONE???? i do not feel like going to the dealer about this!!!!
tmd1029 is offline
