Cold start / no start FIMC question - Ford Powerstroke Diesel Forum
Old 12-07-2009, 09:24 PM
Angry Cold start / no start FIMC question
Ok i have a 2005 F350 i have had no problems out of the truck what so ever ecxept the truck running rough at idle on cold start but the last few days its been like 30 degrees out side i plug my truck in every night but the next morning my truck just wants to turn over, i finally got it started today and drove to work when i went to lunch the truck started fine but when i left after my 8 hour shift it was completly DEAD? I checked my codes and got 7 of them a P2617, P0263, PO336, PO404, PO405, PO611 AND A PO2614.
I know one is for the FIMC but does that mean its for sure dead or do i just need a reflash? I have no warranty i have 126,000 miles on the truck?
Old 12-08-2009, 06:38 AM
Cool thanks for the help. Should have bought a duramax. lol
Old 12-08-2009, 09:13 AM
The first code is for the crank sensor and most of the others are related to that check wireing/plugs
Old 12-08-2009, 09:17 AM
It is sitting at Ford right now im waiting on a call back from them now. It sounds like a exspensive fix?
Old 12-08-2009, 09:20 AM
The crank sensor should not be that much that should get rid of 2 codes the 2 middle codes I could not find listed in my list.
Old 12-08-2009, 09:26 AM
from what i researched the FICM is what is causing the other ones to go bad do you think they wil be able to just reflash or do you think the FIMC is shot?
Old 12-08-2009, 09:43 AM
once a ficm is shot its shot and need to be replaced. the po6011 is pretty much the death code for the ficm, im willing to bet once they replace that all your problems will go away.
Old 12-08-2009, 12:35 PM
Just got my 05 back from ford with same prob an it was the ficm. Cost 855 with no warranty
Old 12-08-2009, 07:09 PM
Well talked to ford it ended up being my glow pug module, one battery and my FICM was shot so a new one of those and a reflash its going to cost me $1500
