6.0 Injector Diagnostics w/o codes?
Ok so here is my story I am having an injector or so I believe thats bad. Rough starting in the morning, puffing some white smoke and idling really rough for about 10-15 seconds. This may actually be a glow plug, but the problems follow me out to the road. If I dont let the truck warm up for at least 5 mins, the first 1/4 mile its missing and bucking then finally smooths out and runs fine at low power settings. When the truck is fully warmed up on the highway it will drive for the most part ok, but if I put too much fuel into it and the TC is still locked, it will buck on me. If I really put my foot to the floor, the TC will unlock and shift down a gear as supposed to, but it will run all broken up missing slightly.
So how do I test my injectors? There is no codes displayed. I have a SCT can I run a buzz test? But thats only going to tell me which one is bad electrically. How do I test them mechanically? How do I pin point what injector is my issue so I am not dropping 8 new sticks in?
Yep sounds like a bad injector or two. Ford can check them and tell you which ones are bad. You can run a buzz test to check also but i dont know how to do that. Good luck.
See the attached TBI it should be very helpful.
SCT wont do a buzz test. You need some better software to test injectors
I have the same issues with my o3 6.0 sticky inj .i put in 5w40 w syn rotella fixed the rough start problem immediately ,i have some (HOT SHOT SECRET) on order, will be here on fri i will let you no if it fixes the rest of my inj prob.look up the hot shot web site ,its worth looking into before you buy new inj.
I would have to ask how cold it was? What oil weight? ccocita made a good point. Mine was doing the same thing with 15-40w. I drove it for about 400 miles and couldn't stand it. Put 5w40 syn in it and cleaned it up. I would try that first and getting it scanned if it doesn't help. Could pull the glow plugs and see if any are wet. If there is then there is your bad injector.
I had the EXACT same symptoms. Turned out that my FICM was only putting out 41v instead of 48v. Replaced that and still had problems. Had to take it into the dealer to test the injectors both mechanically and electrically. I ended up have 5 bad injectors and replaced all 8.
As mentioned, there's no way to buzz test the injectors with the SCT. And FWIW, I didn't throw a single code the entire time. --Snake |
A cylinder contribution test is a good indicator when injectors are suspect.
I just got done dealing with this on mine. I had a shop scan it and it had a "#6 cylinder contribution fail" code. That was diagnosed as the injector. PLEASE PLEASE PLEASE when you get the new injector...whether you put it in or not, make sure you use the 2 required special tools and ensure the "o" rings are good and all there on ur injector. Why? Because the shop that put mine in didn't do that and hydrolocked my motor...I was REALLLL lucky that it didn't do much damage.
