06 F 450 LIFT PUMP OR SUPPLY PUMP - Ford Powerstroke Diesel Forum
Old 12-06-2009, 06:25 PM
RAN TRUCK OUT OF FUEL FINALLY GOT STARTED BACK USING STARTING FLUID DROVE TO SHOP TO DO MAINTANCE OIL FUEL AND GREESE ,AFTER THIS WAS DONE IT WILL NOT START , DO YOU THINK THAT THE LIFT PUMP MIGHT BE BAD PLEASE HELP
Old 12-06-2009, 06:36 PM
Could've blown the injector O-rings by cranking it with ether.
Old 12-06-2009, 06:48 PM
NO DROVE TO SHOP AND DONE SERVICE AND THEN NO START
Old 12-07-2009, 09:20 AM
A simple test for the lift/supply pump is take the top off the fuel filter and with someone watching turn on the key for a few seconds. If the filter overflows the pump is working, by the way do not hold the key on for very long that pump puts out a fair amounnt of fuel you would be surprised how much. This will only tell you if it is pumping fuel not if it is the correct volume or pressure.
Old 12-09-2009, 01:36 AM
if the fuel bowl doesnt over flow and just raises half an inch after taking the filter off would that also mean a bad lift pump?
