stalls.. then starts??? - Ford Powerstroke Diesel Forum
Old 12-04-2009, 08:03 PM
2003 6.0 in a f350 4x4 the truck starts up fine you drive for 5 minutes it stalls...you wait 10 min it will start up again and drive for another 5 min then it stalls again... In the last 2 months the oil cooler, head gaskets,icp sensor have been replaced. I hooked my scanner to it and it has no codes, good hpop 500-600+psi cranking. passes an injector buzz test etc..Ficm syncs 12v suply and 47.5v....
Old 12-04-2009, 11:29 PM
Hmm. What type of scanner are you using? Sounds like a ICP sensor or HPOP leak
