I've got a 04 F-250 6.0 when I start it it sounds like it's running on 6 cylinders after it warms up it's better but it throws codes
P0261 P0267 270 273 276 279 282 hope some one can tell me what this means |
It means your FICM is toast, and needs replaced before it leaves you stranded on the side of the road. 100%.
thats what I was afraid of !
I called about one today and it was $800.00 he said that was without the programming is there somewhere else to get one cheaper?
and thanks a million for the reply |
You can find used ones on the board, or check ebay. They can usually be had for $200-300'ish. You never know how long a used one is going to last though. Might last years or only months.
what about programming?
I'll still have to take it to Ford to have it flashed won't I ? will I need to take the truck or can I just take the FICM to have it done? have you got an idea how much to program it?
thanks again |
If you buy a used one it should work without having to take it in for a reflash. However you won't know what calibration is already on it when you buy it. You can always take it to Ford at your convenience and have it flashed to the latest revision for about $100 I think.
thanks
OK i'm on the hunt for a FICM thanks for the help on this. May take a few days but I'll let you know how it works out
What's your location?
my location
I live in Tupelo, Ms.
