9 Injector codes today - Help Please!
I got these codes on my truck today while towing my tractor:
PO261 - Injector Cric. Low Cylinder 1 PO264 - Injector Cric. Low Cylinder 2 PO267 - Injector Cric. Low Cylinder 3 PO270 -Injector Cric. Low Cylinder 4 PO273 - Injector Cric. Low Cylinder 5 PO276 -Injector Cric. Low Cylinder 6 PO279 - Injector Cric. Low Cylinder 7 PO282 - Injector Cric. Low Cylinder 8 PO611 - Fuel Injector Ctrl. Mod. Perf. Can you tell me what this means? FYI - I have the Banks intake, intercooler, and 4" turbo back exhaust, as well as the Zoodad mod., and the Superchips Cortex programer set at the perfomance mode. Any help would be appreciated. Thanks, Todd. 321-377-3463-cell. Truck ran fine just had all these codes. |
Your truck needs a FICM
Hey man, we run some of your stuff in the keys and out of WPB during the summer for dolphin/hoos! And yes FICM is what it looks like you need! btw we get your stuff from Lott bros.
Thanks, Hillbilly, no-tel-in.
I will get in contact with my dealer. Is this something covered under warranty? I only have about 67k on the truck now. no-tel-in - Glad to hear the lures are working for you and your crew. Lott Bros. are a good group. Let me know if there is anything I can do for you. |
YES, with a $100 deductible.
Just in case before you change that FICM check for a loose wireing connector. Since your reading all cylinders haveing low voltages, I would suspect the first plug, this goes to the PCM.
Took it to the dealer yesterday. FICM bad or on it way out. Should get it back tomorrow, $100 deductible. Thanks for the quick replies. Tight Lines.
