Driving home last night at highway speed I hit a bump and the front end went into "death wobble" worse than it ever has. Had to bring the truck down under 30mph to get it under control. After the violent shaking ended I had almost no power and limped the truck home. Couldn't even get up the drive way. This morning I looked at various data from my DashBoss. ICP/IPR/FICM and Turbo all look good. RPM at idle are jumping all over the place from 620 to 850 and extremely rough and noisy. I'm not a mechanic but fairly handy with this truck. I'm stuck on this one however. My first guess was an electrical connector shook loose somewhere but I've gone through all the obvious culprits and haven't seen anything. Open to any ideas or suggestions.....
FICM is stable at a constant 47.5-48.0
ICPV is fluctuating from 1.00-1.35V Mostly hovering at +/-1.22.
ICPP is fluctuating from 820-950PSI. Mostly holding around +/-920 PSI.
IPR is mid 30s at first start and creeps up to mid 40s as the engine runs.
Engine Load is generally staying 75-99% which is way above normal.
Mass Fuel Desired and Throttle Position are staying at 0. But Absolute Pedal Position is reading normal on all three sensors.
I've never monitored MFS or TPS before this so I'm not sure where their normal range is. Pedal to the floor in Park gets to about 2200 RPM. In Drive tops out at about 1500 RPM.
Messing with the ICP didn't have any effect either. Unplugged it while running. Shut the truck off. Restarted it with ICP still unplugged. Plugged it back in while running. No change in the idle at any point.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
