2006 F350 6.0 cranks won't start. - Ford Powerstroke Diesel Forum
 15Likes
post #1 of 22 Old 03-18-2017, 02:24 PM Thread Starter
Any help will be greatly appreciated. I am new here but have usually been able to read old threads and find an answer. I have read many threads on this and checked many things, and this is where I am.
EGR Delete several years ago, very recently new injectors, new head gaskets, new HPOP and water pump. Ran about a month just fine, was driving down the road, it died and won't restart.
It has diesel, the batteries load tested fine, have checked the emergency cutoff valve and replaced the ICP. IVR screen was clean and not torn, no debris, also have checked fuses and relays. Can see no problems with wires, harnesses or chaffing. Oil is good.
The Torque Pro App with BAXF OBDII readings are:
IPR 85%
HPOP/ ICP 1700 lbs
Added the Extended FICM Sync PID with the Extended Sync for the PCM and Crank and Camshaft
The FICM Sync was at 1, the PCM sync was also at 1 and the Crank and Camshaft PID showed to be 1 and the green light was on.
The FICM logic, FICM Main, FICM Vehicle show nothing, all stay at 0. Have ruled out 304 relay under the hood and the 50 amp fuse under the dash. Those were both good.
Does the lack of readings for the FICM Categories mean that it is the FICM? Are there more fuses or amps anywhere? There is no smoke when cranking.
UnluckyRed is offline
post #2 of 22 Old 03-18-2017, 02:50 PM
jokester00's Avatar
Quoted: 103 Post(s)
Garage
With those numbers, I 'd put a meter on your FICM and make sure you're getting correct voltage.
-jokester
jokester00 is offline
The Following 2 Users Say Thank You to jokester00 For This Useful Post:
UnluckyRed (03-18-2017)
post #3 of 22 Old 03-18-2017, 02:56 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 110 Post(s)
Feedback Score: 7 reviews
check the harness under the FICM, they are known to break. but it looks like your FICM is toast!
UnluckyRed likes this.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
The Following 2 Users Say Thank You to powerstrokeshellback For This Useful Post:
post #4 of 22 Old 03-18-2017, 03:35 PM Thread Starter
Ok, will check these things tomorrow. It's about 75 miles away so if anyone can think of anything else to check please mention it, will go check again tomorrow.
post #5 of 22 Old 03-18-2017, 03:59 PM
jokester00's Avatar
Quoted: 103 Post(s)
Garage
Forgot to mention, check ICPv at KOEO. For giggles, unplug ICP sensor and try to start it.
-jokester.
drivininidaho and UnluckyRed like this.
post #6 of 22 Old 03-18-2017, 04:02 PM
THIS IS HOW WE DO IT....
Quoted: 245 Post(s)
yup, I'd do a voltage check on the FICM. Do you know how to do that?
Zach
07 F250 King Ranch FX4 CCSB, Dark Copper Metallic/Arizona Beige, Rotella T6+Archoil
6000K HIDs, Fog mod/High Idle, Tinted,
Banks CAI, Blue Spring, NUC/Amsoil Bypass Oil Filter
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
138,000 miles....
Air Force Veteran......Go Blue!
"Think of the most attractive person you know. Even that person, at some point, has had raging diarrhea"
Support Our Troops - Remember Our Veterans!
zsargent is online now
post #7 of 22 Old 03-18-2017, 05:30 PM Thread Starter
I think so. Looks like a friend is going to loan me an FICM on Monday also to diagnose. Any words of wisdom or pitfalls to avoid with doing that?
post #8 of 22 Old 03-18-2017, 05:32 PM Thread Starter
No luck unplugging the ICP.
post #9 of 22 Old 03-18-2017, 05:34 PM
jokester00's Avatar
Quoted: 103 Post(s)
Garage
Do you hear your fuel pump come on when you turn the key on?
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running Gearhead 8K Tow Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
post #10 of 22 Old 03-18-2017, 05:37 PM
Powerstroke Techie
Quoted: 473 Post(s)
Don't just fire the ficm in. Check voltage first.
Did you scan it for dtc's? Were there any?
jokester00 likes this.
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
The Following 2 Users Say Thank You to kaya For This Useful Post:
