Oil in coolant... - Ford Powerstroke Diesel Forum
post #1 of 27 Old 11-22-2009, 08:40 PM Thread Starter
Oil in coolant...
So right when i'm ready to drop the dime to get injectors I've found another problem...
Truck has been running fine except for hard start and missing, so I kept assuming injectors issues.
I was doing my routine weekly fluid checks yesterday and the coolant is completely brown and chocolate milk looking...GREAT!!
Is it safe to assume that means oil cooler is busted? I cant think of anything else that would cause this...And what else did it screw up? Water Pump? Radiator maybe?
I'm also not sure how many days i've been driving with it like this...I usually just tap on the coolant tank and see it move around...it didnt move this time so I opened it up and seen the nastiness....OH, and I had just spent 120$ to switch to full-syn....
Any ideas?
Ruben
2008 F250 4x4 6.4PSD Auto
Tuned, deleted, studded, piped, bts'd...
Rubenk is offline
post #2 of 27 Old 11-22-2009, 08:55 PM
jlynch799's Avatar
oil cooler
jlynch799 is offline
post #3 of 27 Old 11-23-2009, 04:45 AM
flushing system
Not only will you need to change the oil cooler but you will need to flush both the cooling system and the oil system. Then replace the oil and coolant with fresh clean fluids. Check the condition of the coolant hoses if they feel mushy you may need to change them as well. Don.t forget to flush the heater core as well.
dannyboy950 is offline
post #4 of 27 Old 11-23-2009, 05:07 AM
BIGBILL105 45's Avatar
Oil cooler. Currently the problem I have.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #5 of 27 Old 11-23-2009, 07:56 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
yep, what he said!!
And as the above stated, its a blown oil cooler. You need to get a water temp and oil temp gauge after you replace the oil cooler, also if you dont have your EGR deleted, now is the time.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #6 of 27 Old 11-23-2009, 08:16 AM Thread Starter
ive had the egr deleted for a while. thanks for the info everyone!
so now I guess ill drop it off at the dealer and try to get my aftermarket warranty to pay for it...great... any advice on how much labor im lookin at here if i gotta pay for it?
oil cooler replace and both systems flushed right? that it?
Ruben
Rubenk is offline
post #7 of 27 Old 11-23-2009, 08:29 AM
Abrannan19's Avatar
labor varies from $110.00-$120.00 per hour depending on the dealer, they will charge 8-10 hours to R&R the oil cooler, plus the cost of the oil cooler rebuild kit.
Adam Brannan
post #8 of 27 Old 11-23-2009, 08:33 AM
Goose350's Avatar
and then another $120 for a coolant filter, he will want it.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #9 of 27 Old 11-23-2009, 02:23 PM Thread Starter
well I talked to the dealer today and I cant get it in till next monday, so that means no ride during the holiday
Apparently my aftermarket warranty wont cover **** either, they said neither injectors or oil cooler is covered...guess i'm gonna have to really tear **** up to get my money's worth out of them!
I had just saved up for all new injectors too...guess i'll fix the oil cooler and rock the 7cylinder powerstroke for a while longer...
Ruben
Rubenk is offline
post #10 of 27 Old 11-23-2009, 03:34 PM
Powerstroke Techie
Buy the oil cooler "KIT" and not the oil cooler itself. It's a little bit of work changing the heat exchanger over the entire cooler - but it'll save you some ching.
Couple hundy if you're in Canada, if memory serves me rightly.
Big Angry Hillbilly is offline
