Random Long Crank and weird voltage. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-17-2017, 08:49 AM Thread Starter
Hey guys this is my first post but have been reading over the wealth of knowledge on this site for a while.
I have a 2007 F-250 with 193,000 miles. After my last oil change I have had a cold miss until it warms up (I'm guessing a sticking injector or two) but today I went to take my son to school this morning and it just cranked and cranked. I cranked it for about 5-10 seconds three times and it finally fired. My scangauge said I had over 500psi of ICP and I had low side oil pressure. FICM Voltage is 47.5-48 during cranking and when running. No check engine light except my EGR code which has been on for a few weeks. Any idea guys??
Second weird thing I've noticed is my voltage on my scan gauge. After the truck first starts it drops down to around 10.5 volts after the truck starts and slowly builds up to 13.8 to 14 volts over about a 5 minute period. Think the alternator is shot??? This is my first diesel so I'm learning. Thanks for the help in advance!!
Sent from my iPhone using Tapatalk
Miceleb is offline
post #2 of 3 Old 02-17-2017, 09:21 AM
backhoebill's Avatar
Quoted: 335 Post(s)
Send a message via Yahoo to backhoebill
I would do a battery test and check/clean of all the cables/connections. I heard something about the alternator doesn't show charge voltage for a minute after starting. Voltage sounds very low though. I would start with batteries.
HTML Code:
'06 F250 4x4, 251,xxx hard miles, IPR egr delete and coolant filter, blue spring, billet wheel, 4" turbo back, Atlas 40, SCT Livewire, Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #3 of 3 Old 02-17-2017, 09:39 AM Thread Starter
Ironically I did that last weekend. The battery terminals were starting to get a little corroded. The batteries are only a few months old and they are holding a good charge. They crank the engine really well too. The batteries are AAA batteries maybe ill run them down and have them checked. I checked the voltage at the back of the alternator and it seems to be pretty close to the same as the scangauge once it is up to 13.5 to 14 volts. I will have my wife fire it up and I will check the voltage at the alternator to see if it is low on initial start up.
Miceleb is offline
