truck won't turn over, battery or starter problem?
Ok, we just had a nor'easter roll through here a few days ago that caused a ton of problems for me. one problem has to do with my 2001 f250 with the 6.0l diesel. i had the truck parked in the driveway of my factory that backs up to the chesapeake bay. well high tide got really high and flooded there, the salt water got up to just above the door line and saturated my carpet some but did not reach my seats. well the day after i started the truck and it ran fine for the next day and a half. then after that it wouldn't start, as if the batteries were dead. so i put a charger on it and let them charge for a day, still won't start. so i think the batteries may have gone bad, so i go to jump start it so i can drive to the autoparts store to buy new batteries, so then i put a jump box on one battery, and then turn the charger to 12v 200amp jump start option on the other battery and still, when i go to turn it over, its like there is no power there, it turns the engine over once or twice and dies out. so my question is, could my batteries be fine and my starter gone bad from the salt water? it feels and sounds like the batteries have gone bad but when i hooked power up to them it still does the same thing so it leaves me to believe the starter is done, any help would be appreciated.
If water got above the starter this would have caused a dead short to the batteries, like hookiing a wire straight from pos to neg. completely draining the batteries. A jump will jjust be absorbed into the batteries basicaly. You might try disconnecting the batteries from each other and do a slow charge on each one at a time. 24hrs should do it if they aren't completely toasted.
I dint know you could get the 6.0 in an '01? Didnt come out til 03 right?
by golly didn't even notice that.typo I hope.
Eather a typo or a whole lot of wrenchin.....
