Noise question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-14-2009, 07:05 PM Thread Starter
Noise question
I have been lurking for years, had a 2004 with the 6.0 no issues. I just purchased a 2006 with 26K miles. I noticed that it has a noise that goes up and down with the engine. As i give it gas it seems to go up, when I hit crusing speeds and put on cruise I dont seem to notice it. It is a high pitched hum? ANY IDEAS? My 2004 never had it. It kinda sounds like a loose ground but it's not coming through the speakers and not as loud as a loose ground usually is. ANYONE ?? THANKS
y_knotme is offline
post #2 of 4 Old 11-15-2009, 01:05 AM
Does this happen only when driveing or does it do it sitting still and just running the engine. If it only does it while sitting still we can eliminate tire and drive train problems.
God I hate noise diagnostics, there are just so;so many things it could be.
A loose shroud,fan; heat shield; turbo;belt;leak in the air induction system, the list goes on and on.
dannyboy950 is offline
post #3 of 4 Old 11-15-2009, 01:24 AM
taskforcefreddy's Avatar
Sounds like you're getting Altenator feedback through your stereo. Is it stock or aftermarket? Usually means a wire is poorly insulated or a speaker wire is shorting out. Generally doesn't hurt anything... is just more of a nuisance.
EDIT: Just caught the "NOT COMING THROUGH SPEAKERS" part. Sorry about that.
taskforcefreddy is offline
post #4 of 4 Old 11-15-2009, 05:42 AM Thread Starter
It happens only when moving, I start to hear it about 1600rpm . But again when i get up to speed then I don't notice it. It seems to go away or it is not as prevelant. I would say the truck has normal tire noise but this is coming just from the engine.
I may just take it into my local dealer and have them do a test drive to see if it normal. SHOULD I TAKE THE EDGE CHIP OUT OF THE TRUCK, (WILL IT AFFECT MY DRIVETRAIN WARRANTY?) Don't have anything like that in my other one.
y_knotme is offline
