need help! truck is down - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-14-2009, 06:24 AM Thread Starter
I was losing coolant and found it coming out the exhaust. I figured it was the EGR cooler and oil cooler. Now that I have torn it apart and drained the oil I have water in the oil. Head gaskets? I tested the egr have ***'d last night. I filled the coolant side with water and pressurized it with air and it leaked out. Is there any way the oiler cooler could have caused the oil and water mix in my oil pan? So I guess I need to know if there is a way to check headgaskets or should I just yank the heads? any help appreciated.
2004 F-350
6.0 L
5 inch custom exhaust
K&N cold air kit
ARP studs and black onix gaskets
Egr delete
With more money in parts then payments
cnidy1230 is offline
post #2 of 8 Old 11-14-2009, 12:11 PM
STORMTROOPIN's Avatar
if gaskets and arps are in your budget id say do em'. Youve already got alot torn down so why not go the extra step. Your gona need a compresion tester and leakdown tester to see if the head gaskets are bad though.
04' F350 PSD
4" Superlift
35" Nito Teragraplers
16" Eagle racing wheels
Home built 5" Side exit exhaust
RCD full egr delete
STORMTROOPIN is offline
post #3 of 8 Old 11-14-2009, 01:29 PM
If you have alot of miles or suspect bad rings a leakdown test is going to show a leak.
yes your oil cooler can allow water into your oil. there are threads that discuss this, personally never delt with mine.
White '05 crew longbed 4x4
6-ohPonyhaulR is offline
post #4 of 8 Old 11-14-2009, 01:30 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Your oil cooler has ruptured and needs replacing. It's likely due to casting sand accumulating in your oil cooler coolant passages and restricted it so that it ruptured. Need to get a coolant bypass filter to prevent it from recurring.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 8 Old 11-15-2009, 01:23 AM
While I agree you need an oil cooler, I have seldom seen just an EGR cooler leak put water in the engine oil. You may have another issue going on as well.
Do you have a peanut butter oil condition or was there just some water came out when you pulled the drain plug.
dannyboy950 is offline
post #6 of 8 Old 11-15-2009, 04:59 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
I have NEVER seen an EGR cooler put water in the engine oil. Please explain...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #7 of 8 Old 11-15-2009, 06:02 AM Thread Starter
there is only some water in the oil. Not alot. I am going to pull the oil cooler today. can you see if it is ruptured?
2004 F-350
6.0 L
K&N cold air kit
Egr delete
post #8 of 8 Old 11-15-2009, 07:53 AM
oil cooler leaks
You will more than likely see cut/damaged orings. Damage to the tubes themselves unless it is on the external edges you may not see. A pressure test would need to be done to find that.
