what is the little - Ford Powerstroke Diesel Forum
Old 11-11-2009, 02:41 PM
what is the little
part behind battery infront of blower motor that makes noise when ignition is on before it starts and after you cut it off
Old 11-11-2009, 02:42 PM
285,261,190
sound like the vacume pump?
Old 11-11-2009, 02:50 PM
ok im not a ford guy its a friends if it is bad will the truck not run or start
Old 11-11-2009, 02:53 PM
fuel pump? im not sure what you are talking about
Old 11-11-2009, 02:59 PM
i think he is right i looked and it does have vac lines going to it
Old 11-11-2009, 03:29 PM
Powerstroke Techie
I agree with this statement. It IS the vacuum pump.
Old 11-11-2009, 03:31 PM
will the vacume pump cause it not to run
Powerstroke Techie
If this part were to fail, his front auto-locking hubs would fail to engage when he selects 4x4, and his mode select functions would default to defrost only in all mode select positions on his HVAC.
Old 11-11-2009, 03:36 PM
its two wheel drive
Old 11-11-2009, 03:42 PM
ok changed all the fuel filters truck ran good for about a week then parked it overnight and then truck didnt want to start after it did would only idle but ran rough now wont start at all the vacuume pump used to be loud but now its quite
