white smoke!!! - Ford Powerstroke Diesel Forum
Old 11-10-2009, 04:57 PM
white smoke!!!
about one year ago i put mbrp exhaust on my 2006 f250 diesel
it slowy start to white smoke
now when i stop at a stop lights it puts out a lot!!!! of white smoke
is one of my inj tip broken????
Old 11-10-2009, 05:07 PM
White smoke is usually coolant leaking into the exhaust. A blown injector, excessive fuel would be black smoke.
Old 11-10-2009, 06:31 PM
I just recently installed a 4" turbo/back mbrp w/ no cat. With in a day I noticed puffs of white smoke when taken off from a stop. Brought it in to the dealership. Turned out to be the turbo seal starting to leak.
Old 11-30-2009, 05:53 PM
I installed the same exhaust on the same truck. same problem. but i waited and finally took it to the dealer. 2 bad injectors and egr cooler, oil cooler, and turbo conditioning is what they did. then had to take it back within a week to have the egr cooler replaced again! they said the heads were fine. and guess what it still does it! good luck
