2003 icp sensor help - Ford Powerstroke Diesel Forum
Old 11-10-2009, 10:56 AM
Send a message via AIM to maddenjr
Hey guys im a mechanic and i have an early 6.0 here that has a bad icp sensor but im not seeing it.Does anyone know the easiest way to change it???
Old 11-10-2009, 11:27 AM
The ICP sensor is behind & under the turbo. You need a 1 1/16 socket to remove. I cut my socket down to just fit the sensor. I used a socket, swivel, extension, and then wrench to remove it. It is a TIGHT fit. I removed the driver battery, air filter, FICM, unbolted the degas bottle. Then remove the connector from the IPR valve, then remove the connector from the ICP and remove the sensor. See some attached pictures of items removed and location of ICP sensor. It is the one with the heat shielding.
Old 11-10-2009, 11:29 AM
Well that didn't work as I expected. Attached is a overview of the engine.
Old 11-10-2009, 11:36 AM
I paid someone to do mine but I have been told you can reach it (with really long arms and alot of patience) from under and behind the engine. Good luck on this one.
Old 11-10-2009, 12:39 PM
OK DONE THANKS FOR THE CLUE MY SHOP COMPUTER HAD NO INFO AND I JUST WANTED TO MAKE SURE I WAS CORRECT WERE I THOUGHT IT WAS...THAT WASNT FUN BUT NOT THE WORST IVE DONE ON THESE TRUCKS LOL
Old 11-10-2009, 04:48 PM
Send a message via AIM to goXtreme Send a message via MSN to goXtreme
I just had all of that stuff off of mine and I could not get an ICP sensor until this Thursday, so I put it all back together...
Old 11-11-2009, 02:37 PM
I know its a pain. But when i replaced my icp and ipr sensors i pulled my turbo for a little extra room. It seemed to help me a little bit.
Old 11-11-2009, 05:03 PM
NO NO gooseman55 all you need is a 1 1/16 shallow impact socket 1/2 drive to 3/8 adapter with a swivel and 6" extension and it comes out man..Its a pain to start the new one but im a big guy and i got my fingers in there!
Old 11-11-2009, 05:24 PM
That is reassuring, because I am sure I will be changing mine, thanks for the info
Old 11-11-2009, 06:31 PM
its cool goose.. i pulled my turbo also when i had to replace on my old 03.. makes it a lot easier.. still a pretty pita job though
