| View Poll Results: Best way to install head gaskets and arp studs on an 06 6.0 | |||
| Remove cab from chassis |
10 | 83.33% |
| Remove engine from chassis |
0 | 0% |
| Replace Head Gaskets and ARP Studs with motor in the truck |
2 | 16.67% |
| Other Options (lemme know if yall have other ideas) |
0 | 0% |
| Voters: 12. You may not vote on this poll | |||
Questions about 6.0 Head Gaskets and ARP Stud Install.opinons greatly appreciated!!!!
iam about to tackle replacing head gaskets, head studs, egr delete, upgraded injectors and turbo install on a 2006 f250 4x4 6.0. ive heard so many different ways about going about the install. ive heard you have to pull the cab, ive heard its easier to pull the motor, and ive even as of late heard its easiest to just do it in the truck. i see alot of members with similar mods to the ones im about to install and it seems alot of yall do your own installs, so which option did yall choose when yall did head gaskets and studs? which would be easier overall, which would be quicker? i have a two post lift in the case that i remove the cab. it just seems like removing the cab would create alot of extra work but my main objective is to go with which ever route would make the job go the smoothest and without problems. so what yall think thanks for any advice yall might have to share in advance i appreciate it
brandon |
Hey I did my head gaskets and studs and a few other mods this summer. I did a big write up on it with a bunch of pics. I did it cab on motor in the truck, i removed the ac box. It was very easy. Reminded me of working on a camaro. I had 26 hours into the project start to finish and I installed a new exhaust and a few other little things. It was well worth it and if I get another 6.0 it would be the first thing I did.
Cab Removal
Hello.i am just doin the heads,egr,exhaust and a few other minor updates and i just pulled the cab it took about 2.75 hours to get the cab in the air also have a two post hoist ,without the hoist yes i would have done it with the engine in the body
brandon |
brandon |
brandon |
Heres a link to my job Head gasket and stud install
thanks again brandon |
